24v/common rail question
Old May 8, 2010 | 10:25 PM
vj_M's Avatar
had this in the 6.7 forum before so i changed it to here ...
not sure if i should ask this here or somewhere else, but here goes. I have low compression on the truck (in sig) and i want to know does if a 24v motor from a 98.5 to 2002 could be used in a common rail?
like, if i took everything off of the common rail ie. injectors, head, turbo etc and put it all on a motor from a 98.5-02 would this be the same block?
its hard to find common rails but 98.5 and 02's motors are everywhere i look.
just wondering if anyone knows anything about this.
VJ
Old May 8, 2010 | 11:09 PM
RWDCelicadude's Avatar
So you want to know if the block from a 24v is the same as a common rail block, ie. are all the coolant passages, bolt holes, oil return holes and mounting bosses either the same or interchangeable.
I have no idea but I know that you don't want to get a 53 block if you do get one. They had thinner castings and were prone to crack, especially if you added power or towed excessively heavy.
Old May 8, 2010 | 11:56 PM
vj_M's Avatar
ya, thats what iam asking, i know about the 53 blocks and i think 2000-2002 are ok but i want to know if i could use one of these blocks for a rebuild for my 2005.
Old May 9, 2010 | 11:29 AM
Smithereen's Avatar
Why don`t you rebuild the original?
Old May 9, 2010 | 01:33 PM
Jim O's Avatar
VJ
In the original sales info that I have for my HO 03 it says "block structure changes for NVH stiffened block, sculpted side walls, bed plate, greater durability for block oilpan and for lower noise.
Jim O
Old May 9, 2010 | 05:20 PM
vj_M's Avatar
i was just thinkin it would be easyer to do it this way and scrap the rest, i don't really want to be into this truck another 5G cuz iam still paying for it and i can't drive it.
but if the block has some changes then its probley not going to work...
Marty86
Sep 11, 2007 07:31 PM
00 5.9 ctd
Nov 2, 2006 01:40 PM
cwert87
Oct 19, 2006 08:37 PM
