24v Common rail -05 Low on power
Old Jun 12, 2017 | 03:11 AM
Olav's Avatar
Hi from Norway! This is my first post here. I'm helping a frien of mine. He's working on a truck/ motorhome with a Common rail engine. I'm known with conventional diesels but I have limited knowlege of common rail. The issue is that it will only rew approx 2200rm under heavy load/ uphill. Flat or downhill no problem. Neutral revs OK. There is no engine fault light on dash. We had a brief look at filters etc but can not find any obious problem. If we drive uphill it struggels and come back on full power/ rpm after some seconds after flattening out. I suspect the Return valve ? Are there any issues that normally cause this. At moment we don't have OBD code Reader as this truck have 6 pin Connector, not the common OBD2 Connector. Regards Olav
Old Jun 12, 2017 | 12:35 PM
gcssr's Avatar
If U have dual tanks, check the selector valve, years ago ,I had a gas MH doing the same thing , flat , level ran fine after months of trouble shooting, i found the tank selector valve would leak and allow the system to pull air in, changed the tank selector valve problem solved.
Old Jun 13, 2017 | 10:38 AM
Olav's Avatar
Thanks,we will look into this. Olav
Old Jun 13, 2017 | 04:39 PM
gcssr's Avatar
Also check the pickup tube coming out of the tank, there is a filter on tube that may be plugging up inside tank,,
vj_M
May 9, 2010 05:20 PM
Marty86
Sep 11, 2007 07:31 PM
spots
Mar 18, 2003 07:14 PM
