235 Flashed to 305
Old Jan 17, 2005 | 12:29 PM
4X4 HULK's Avatar
Exclamation 235 Flashed to 305
Can someone tell me if my 03 with 235hp ca model can be flashed to 305hp at the dealer?
I'm going the the dealers tonight on some other issues.
Old Jan 17, 2005 | 01:08 PM
Corwin's Avatar
Don't believe you can, thinking that way after reading this
http://www.cummins.com/na/pages/en/p...DB80C4A8F00000
Old Jan 17, 2005 | 10:49 PM
zzsdad's Avatar
That's BS. You know the programming was the deal. The other stuff is just foof.
Old Jan 18, 2005 | 02:46 AM
PourinDiesel's Avatar
Power wise, the programming is the difference.
Old Jan 18, 2005 | 08:38 AM
tcb's Avatar
tcb
in theory it should work, but i doubt it a dealer would do it. if they do let us so guys know where he is, it might be worth the drive.
tim
Old Jan 18, 2005 | 10:25 AM
Mark Thomas's Avatar
After reading that, I thought all these 3rd gen trucks had oil spray piston cooling. Am I wrong on this?
Old Jan 19, 2005 | 08:38 AM
nickleinonen's Avatar
all the cummins b series engine have the oil piston cooling jets, just different types...
quote from factory service manual (page 9-329 from 2003 manual)
Piston cooling nozzles cool the piston and
pin with engine oil supplied by the crankshaft main
journals. High horsepower pistons are gallery cooled
and utilize J-jet piston cooling nozzles.
Old Jan 19, 2005 | 05:22 PM
bigblock2stroke's Avatar
I think the manual should have said High HP engines have J-jet piston cooling noozles and standard outputs are gallery cooled.
I have done this and it works fine, but you're right the dealer won't let you.
Old Jan 20, 2005 | 08:15 AM
4X4 HULK's Avatar
I haven't gone to the dealers let, to must stuff to do. It seen to be the option that the dealer will not flashed new code and if they won't how do I do this???????
Old Jan 20, 2005 | 08:19 AM
I would think, just locate a wrecked HO. truck and get the ECM from it?
Old Jan 20, 2005 | 08:49 AM
Patrolman808's Avatar
This was my thinking as well, but some guys on another site said that they were totally different engines, so I dropped the idea.
Old Jan 20, 2005 | 09:49 AM
Mike67RS's Avatar
Try a box. I am real happy with my edge ez...and I also have the 235HP CA engine.
Old Jan 20, 2005 | 05:29 PM
Hounddog's Avatar
The dealer has no way to flash one from one spec to anothr.The flash up grades are supplied to them from the MUCH higher ups.A fash destroys info and upgrades the software with NEW info.the Dealer does not have THE info to increae horsepower.swapping Ecm's may work.May not.If I'm not mistaken the ECM'S are burned with a vin number to match each truck built.I don't think they will interchange.I could be wrong but I think its a feature to stop the bootleg/stolen electronis business.Also for EPA purposes.
Old Jan 20, 2005 | 06:02 PM
If the ECM is similar to the LS1 Camaro and Trans Am I had, you could interchange ECM's as long as the year was the same on the ECM's. But it would be easier to just add an Edge box and be done with it.
Old Jan 20, 2005 | 06:15 PM
Hounddog's Avatar
I might be wrong but I think if swapped from one truck to the next they get locked out.I remember at the dealer I worked at wanting to pull a ECM from a new truck to try in a customers NEW truck, trying to diagnois a problem.After 2000 I think it could not be done because the vin was encoded in each respective ecm.
