2005, 3500 Won't Crank
After visiting a tourest attraction in Texas I got in my truck and it will not crank. When I turn the key to start I get a click as if battery is low. Using my meter I have 12.6 volts in each battery.
I called a mechanic from a local very small town who sent a young fellow out. After checking the batteries under load, he determined the starter was bad (I didn't think so). While he was gone to the next city to get the starter I had a small heart attack and was in the hospital these past four days. The new starter did not solve the problem. The mechanic told my wife he now thought it was the computer. I don't know if he was talking about the ECM or what. Anyway I'm out of the hospital and we will be returning to get the truck if it is fixed next Monday.
Do any of you have an idea what might be the cause?
With key in start position only a click
Batteries fully charged
Starter is new
Please help. We are somewhat stranded in Western Texas. I don't want to go about replacing parts to discover the true problem.
Starter is new
If its clicking its not a safety switch. I would be cleaning all battery cable clamps, BOTH sides, first along with the cable to starter connection. Next would be a bad solenoid, high current side. I've never looked, I assume its on the starter? If new it should be good.
Did he do an actual 'load test' of the batteries or a voltage reading with a load on it? How much load? How old are the batteries? Will it start with a jump? A battery can fail intenally but still read good voltage until high demand is applied.
My truck is auto trans. Because of the clicking I figured the neutral start switch is Ok. I'll clean the battery terminals again. I don't know if he checked the voltage under load but I believe so.
What the heck could be the computer he is talking abvoue. Isn't the ECM the only computer?
There are a bunch of computers on these new trucks, one for engine, tranny, ABS, airbags, body control module........ I'm sure there are more....
However I don't know if the starter cct runs through one of them or not or is just relayed off of the key switch. I'm guessing that it does, the N saftey probably feeds to the BCM which would then ok starting.
Either way if something is clicking under the hood then the starter solenoid is getting its signal feed.
As said above you can have a bad battery read 12v but take a dump when a load is applied, a simple boost would reveal that.
A bad clamp or battery cable could show 12v and then take a dump when a load is applied. Have they tried boosting directly onto the starter itself?
Starter is new
Starter is new
The hec with the starter problem. How are you feeling is more important? Tell me where abouts in west texas your at.
Darrell
I am fine. My heart attack was mild and a wakeup call to start eating right, loosing weight and exercising. As of this date (Sunday) we are still sitting here in Fort Davis, Tx. When the sun comes up I will give the battery terminals a good cleaning.
cLAYH mentioned the starter solenoid relay. Where exactly is that located?
Thanks everyone for your help and concerns.
As a side note: we never like to be broken down, but say what you will about West Texas, you couldn't find a more helpful and caring bunch of people.
I got to thinking.
*When the mechanic shorted across the starter terminals (or whatever) the truck started. Wouldn't that suggest the batteries are OK?
* Turning the ignition to the start position results in a "click." The ignition switch is Ok
Would a bad starter relay solenoid produce a click and nothing else?
I need to determine exactly what is clicking. Will report back.
Yes, batteries and cable connestions should be fine
Yes, ignition switch should be fine
Yes, bad starter solenoid.
Replace it when you find it. Its usually on the starter. What ever he jumpered (shorted) is shot.
Good luck, it shouldn't be too tough to fix.
