2005 2500 Cummins Engine Rebuild Wont Start
Old Dec 17, 2012 | 06:11 PM
2005DFS's Avatar
I just rebuilt the motor, also put new injectors in. Won’t start. When I turn the key on the lift relay turns on and off and the lift pump runs constant. Also can’t get edge insight gauge set to install or cannot get scan tool to work. Any ideas would be great. Engine was out comple rebuild had 2 bad cylinders, broken rings. Tried unplugging and reconnecting the connectors, did not help. The fuel pump relay just goes click click click constantly, also the pump is clicking, if i dissconnect the plug on the cp3 pump then the feul realy clicks at half the rate. Is this by chance how it purges the air? If so do i possiably have a leaking connector tube? But this still does not answer why i can not connect insite guage or .
Old Dec 17, 2012 | 08:31 PM
06RAM2500's Avatar
With the pump running (turn the key on, then bump the starter), open the filter drain and see how much fuel runs out.
Old Dec 17, 2012 | 09:15 PM
2005DFS's Avatar
solved the problem, had a ground wire in wrong place. But now i have a new problem truck starts and runs fine, however when it idles i loose oil pressure get error code P0524, not sure if it is the sensor, or another issue, i will have to get a manual guage and check it off the top of oil filter.
Old Dec 19, 2012 | 11:50 AM
2005DFS's Avatar
yup just the sensor machanical gauge shows good pressure.
Old Jan 12, 2013 | 06:13 AM
2-Stroke's Avatar
Where did you get your engine rebuild components?
Old Jan 12, 2013 | 07:57 AM
2005DFS's Avatar
i got it from here
http://www.cumminsperformanceparts.c...cuenovki1.html
Old Jan 13, 2013 | 06:48 PM
2-Stroke's Avatar
Thanks!
DallasDodge2500
50
Jan 5, 2014 02:40 PM
Txbigfoot
May 2, 2013 09:07 PM
johnny1509
17
Feb 18, 2011 07:51 AM
Mike337
Aug 2, 2010 02:16 PM
takkunram
Apr 13, 2010 05:24 PM
