2004 Trans Questions
My 2004 (and not the half) has the tow/haul button on the gear selector. Does that mean that I have the newer 48re trans or is that still the 47re with a few updates? And if it is the 47re will it down shift as I am going down grades with the cruise set?
FLYINHIGH 79 What your tow haul button does is lockout 4th gear. You do have the 48re trans but you dont have downhill lockup of the torque converter for downhill motor brakeing. For 2005 they droped the 4th gear lockout ,- replaced it with tow haul mode which raises the shift points to higher rpm and added torque converter lockup for downhill motor brakeing. For 2006 they put the 4th gear lockout back in along with the 2005 tow haul mode. The 2006 setup should work well
47re or 48re
How do I determine which trans I have?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Waiting delivery on ebay auction
tow/haul button locks out 4th gear. going down hill if ttc is in lockup and cruise is set it will downshift if it exceeds about 10km/hr from set speed. If tow/haul mode is activated it will shift to 3rd and providing you are above 70km/hr(45mph) ttc will lock and hold you going down hill. use brakes as required though
just did this on the weekend pulling my 5th.
Thank you for all the great information. I noticed the other day while not in tow/haul even going down a steep grade at about 45mph, the veh did down shift from over drive to 3rd but I want going fast enough to mean a whole lot. Kinda suprised me. Thanks for all the help on this info. Again I am kinda knew to the site but I like it already.
2003 S.O. Federal Emissions: 250HP/460lb.ft. Available with NV4500 or 47RE
2003 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 47RE
2003 H.O. Federal Emissions: 305HP/555lb.ft. Only available with NV5600
2003.5 The 47RE was replaced by the 48RE automatic transmission
2004 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 48RE
2004 H.O. Federal Emissions: 305HP/555lb.ft. Available with either NV5600 or 48RE
2004.5 (50 state legal) 325HP/600lb.ft. Available with either the 48RE or NV5600
2005 (50 state legal) 325HP/610lb.ft. Available with either the 48RE or NV5600
2005.5 The NV5600 replaced with the G56 6spd manual gearbox.
equipment code
http://store.dodge-diesel.org/dev/pr...threadid=60274
<<<Regardless of the engine, there's also an "Equipment Identification" label in the glove compartment. If your label has "DGA" beside the transmission, it means it's a 4spd auto. The next line will be "DG8" if it's a 48RE or "DGP" if it has a 47RE. The label will also show whether or not the torque converter is locking type or not.>>>
If the above quote is true, my dodge manufactured 5/03 has a 48RE regardless of engine. I am very glad.
Hetdiesel
May 23, 2009 07:40 PM
bmallen
Feb 29, 2004 10:30 PM
Huntindad
Feb 9, 2004 06:45 AM
