2004 Tranny Question
Old Jun 28, 2008 | 07:58 PM
Flanman5's Avatar
My tranny when in TOW HAUL will not go into overdrive, what can i do?
Old Jun 28, 2008 | 09:33 PM
forwardho's Avatar
It is not suppose to. Tow/Haul locks out overdrive!
Old Jun 28, 2008 | 10:38 PM
shortbed rv's Avatar
As forwardho said n model year 2004 tow/haul is a overdrive lockout.On 2005 tow/haul changes the shift points but does not lockout OD. 2006 has the option to do both od lockout and a true tow/haul.
Old Jun 28, 2008 | 11:33 PM
Flanman5's Avatar
oh ok well that is crappy it revs so high.
Old Jun 28, 2008 | 11:35 PM
Flanman5's Avatar
No way of getting it to lock up is there?
Old Jun 29, 2008 | 03:20 AM
annabelle's Avatar
Do a search for a switch that resloves the problem. I haven't done it, but I think a solution exists.
Old Jun 29, 2008 | 05:46 AM
kry226's Avatar
Just use Tow/Haul to get the rig moving and up to speed and then hit the button to allow O/D to engage.
Old Jun 29, 2008 | 04:04 PM
Tiara3100's Avatar
Since tow/haul only locks out overdrive on my 04.5, I just leave tow/haul off when I'm towing my 8,000lb camper. Seems to have no problem towing it and I get better fuel mileage. The motor turns 1800rpm at 65mph, which seems just right for this engine. (Stock tires (265/75/15) for the summer with 3.73 gears). If I tow in a hilly terrain, I may turn on tow/haul again until the road flattens out.
If I'm hauling heavier, over 10K, I will leave tow/haul on and stay under 60mph.
gsdog1
Aug 3, 2004 10:01 PM
drno
Jun 18, 2004 06:57 PM
bmallen
Feb 29, 2004 10:30 PM
shortround
Feb 28, 2004 12:06 PM
Huntindad
Feb 9, 2004 06:45 AM
