2004.5 towing
Old Jan 29, 2006 | 10:44 PM
dylan's Avatar
2004.5 towing
Hello Gents,
How well will a 04.5(2500) 4x4,QC, auto,4:10 with short bed do towing a 13000lb.(toy hauler) pull trailer?
Regards, Dylan
Old Jan 29, 2006 | 11:12 PM
no_6_oh_no's Avatar
I predict you will pass every Powerpuke and Duraturd you come upon!
(well, maybe not EVERY one, but, that problem can be solved easily)
Old Jan 29, 2006 | 11:16 PM
Equalizer 2's Avatar
The truck and driveline will handle it just fine. Watch out for your hitch weight as that would give you a weight of 10% or about 1300 lbs on your hitch. You will need to make sure you have a Class V hitch installed and probably want to use an equalizer hitch. I pull a high profile 5th wheel that weighs about 9000 lbs and have 3.73 gears, it works great.
Old Jan 30, 2006 | 10:04 AM
badram's Avatar
I pull a toyhauler loaded at 11000 lbs with an 05 srw qc xzt tow mod quad intake and mbrp dont even know its back there, I did pull it bone stock w/no prob. just watch egt's on hills and onramps, but modded is night and day, def get sway control , mine is 32 ft and that made a big improvement.
p.s. 2wd , auto , 4.10's
Old Jan 30, 2006 | 11:25 PM
dylan's Avatar
Thx Gents,
I won't have that big of a load, I just wanted to know if the truck could handle the GVWR of the trailer. I like my truck more every day...
Dylan
gsdog1
Aug 3, 2004 10:01 PM
drno
Jun 18, 2004 06:57 PM
bmallen
Feb 29, 2004 10:30 PM
shortround
Feb 28, 2004 12:06 PM
Huntindad
Feb 9, 2004 06:45 AM
