2004.5 engine replacement questions?
Old Sep 16, 2007 | 06:02 PM
upjeeper's Avatar
hey guys
I'm considering purchasing a 2004.5 CTD that needs a motor. I've heard dodge charges $13k for a new motor and Cummins will sell a longblock for $7900.
What do you recommend for finding a new one and what should I pay?
Also, i don't really have the time to do the swap myself, so what should I consider paying to have this done? Can you guys recommend someone in between MN and Arkansas to do the work?
thanks
Nathan
Old Sep 16, 2007 | 06:55 PM
Jfaulkner's Avatar
Muted User
they're around. I'd check Ebay or TDR/DTR's classifieds. I know Fordcummins.com has some for sale. Depending on what's wrong with the junk engine you may not need the whole thing.
Old Sep 17, 2007 | 11:36 AM
wardy70's Avatar
What is wrong with the old motor? I was going to buy a longblock because I had broke the crank in my old motor. I went and bought a boneyard motor for 4K and brought it home and it was full of rust and junk so I took it back and I was back at square 1. We ended up replacing the crank in mine it did no major damage to anything and ended up costin 1300 in parts. If you know someone that is good mechanically you might save yourself alot of cash. From what I have seen it takes alot to really seriously hurt these motors.
Old Sep 17, 2007 | 01:17 PM
SSminnow's Avatar
First of al, really no reason in buying a brand new motor, unless
1)You have money to burn
2)You just want a new motor and you also have money to burn
Depending on what is wrong with teh motor you have, I would fix that one. Hole in a piston? Broke crank? Cracked block? what?
You can also find them in junkyards, with a warranty backing it up. Either way, it will be considerably cheaper than buying a new motor. To swap motor's, taking one out,and putting another one in, hooking everything up, etc...you are in the neighborhood of $1500+ Looking at 6-10 hours for removal (depending on the shop) and 6-10 hours for install. 20 hours @ $75 hour =$1500. If you can get someone to do for say 12 hours @ $60 hour, you are at $720, which I would say is on teh way cheap side. You are also looking at fluids, and misc....which of course adds to the total.
So, what is wrong with the motor?
Old Sep 17, 2007 | 05:50 PM
upjeeper's Avatar
not positive what's wrong with the old motor (i'm looking to purchase it). i was told it had knock and the motor was removed so i can't check it out without tearing it down
how difficult are rebuilds on a 5.9? i'm doing a rebuild on a subaru 2.5 right now
Old Sep 17, 2007 | 06:36 PM
isbeinside's Avatar
super easy to build, if you can build a 2.5L subby engine you can handle this, just remember everything weighs more then your whole subby engine.
Old Sep 17, 2007 | 07:27 PM
upjeeper's Avatar
ha ha ha
i think the 5.9 crank weighs more then my subie engine...
Hetdiesel
May 23, 2009 07:40 PM
drno
Jun 18, 2004 06:57 PM
bmallen
Feb 29, 2004 10:30 PM
shortround
Feb 28, 2004 12:06 PM
Huntindad
Feb 9, 2004 06:45 AM
