2003 injectors
Old Mar 23, 2009 | 07:26 AM
12valvedutchy's Avatar
2003 injectors
HeyGuys , I may have a possible injector already broken or on the brink. Could anyone give me some help or hints on how to check to see which of my injectors is leaking down or broken. Thanks. Jordan
Old Mar 23, 2009 | 08:13 AM
homewrecker's Avatar
What problems are you having?Rough idle,hard start,white smoke?
Old Mar 23, 2009 | 08:47 AM
michigan mark's Avatar
Take off valve cover and you will see injectors, There are two wires on each injector. Take one wire off one inj and start ,do this till you find the bad one.Dont touch wire while running!
Old Mar 23, 2009 | 01:26 PM
Thanks for the help. Well it started starting hard about three weeks ago and so i have changed the fuel filter twice now. Each time it would start excellent for about 3 or 4 days then it went back to usual. On occasion it will crank forever before starting. Also last friday after a no cranking real easy it had a rough idle with a rough vibration in the cab. Lift pump is a Carter and is only about 15,000 miles old. TIA
Old Mar 23, 2009 | 01:36 PM
Also truck shows code po477, Exhaust control pressure relay low Any ideas of what that is or means?
KRB
May 20, 2007 06:20 PM
BIGOKIE
Jul 21, 2004 05:53 PM
turbov6joe
Feb 11, 2004 12:51 PM
shortround
Aug 22, 2003 02:50 PM
Mopar_Mudder
16
Nov 15, 2002 12:51 PM
