2003 3/4Ton AC HELP
hey guys
2003 3/4Ton Cummins 5.9 Quad Larime HD 4X4
having an issue my a/c wont ingauge anymore system is fully charged. but have NOT attempted at topping it off
here are some pictures of some weird wiring l discovred "maybe sombody here use to own this truck" and can help me.
its 30c out every day now and windows arn't cutting it anymore Besides my windows don't go down anyways only accessable by drivers controll and that broak lastnight droped my beer on it bust the pannel out.
l didn't spend my high dollers Education investment for a lemon pick-up thats made me 20grand thisyear sofar.
l need some help
THE DODGE!!
l need some help
THE DODGE!!
If the freon is topped off to the correct level check the pressure switch if the compressor clutch isn't engaging. Also check for power to the compressor clutch.
Not sure what the pictures are supposed to show, but is the radio aftermarket?
MikeyB
MikeyB
if it is not blowing at all like the blower motor is out try playing with your ignition switch. wiggle it back and forth and see if the air comes on. their was a recall on some of the half tons for this issue because the switch goes bad due to dc useing a small diamater wire for the switch. the recall replaces the ignition switch and comes with a two wire harness that plugs in to the big pin connector, the small pin connector for the ign switch, and the blower motor if my memory serves me.
dodgerdog
24
May 10, 2009 09:11 PM
wadecool
31
Jul 21, 2007 01:04 PM
withalligators
May 6, 2006 11:22 PM
