'07 5.9L and Power Service
Old Oct 29, 2010 | 01:45 PM
RBulldogger's Avatar
This stuff.... http://www.facebook.com/photo.php?pi...&id=1497488111
How often, and how much? Thanks in advance!
Old Oct 29, 2010 | 01:53 PM
Colo_River_Ram's Avatar
With age comes the cage
I use it when it drops below 0, when it drops below -40 I normally double dose it. In the summer I will use their silver and or Lucas conditioner..
Old Oct 29, 2010 | 01:56 PM
Appreciated. This jug says it's a year-around formula...
Old Oct 29, 2010 | 02:09 PM
How often (every fill?) and what did you use to measure it out to add to your tank? How much exactly are you using? Take me through the process please.
Old Oct 29, 2010 | 02:47 PM
rockcrawler304's Avatar
If using for anti-gel then you will need it in every fill up. They do have the instructions for how much on the back of the bottle. I use the silver bottle in the summer and have a clear plastic container with ounce markings on the side to measure mine.
Old Oct 29, 2010 | 03:03 PM
How often are you using it in the summer?
Old Oct 29, 2010 | 03:36 PM
Every time you put fuel in the tank you add the appropriate amount of your chosen conditioner (like posted above the instructions are on the label)
Old Oct 29, 2010 | 06:32 PM
That often eh? Thanks, gentlemen. I know a lot of people not using anything at all... for 100,000km or more.
Old Oct 29, 2010 | 08:10 PM
Condor's Avatar
I use the gray bottle most all year unless it gets really cold then switch to white bottle. I use half oz power service and half oz 2 stroke per gallon fuel,
I use an empty mystery oil bottle to measure amounts. Been using it in both my trucks every fill-up since new.
Old Oct 29, 2010 | 10:25 PM
I use the PS every few fill ups. I also use 2 stroke oil, again every few fill ups.
Old Oct 30, 2010 | 08:19 AM
92'1stGen's Avatar
I use the gray bottle from about mid-april to early-oct, and then run the white bottle from mid-oct to mid-april. 16 oz. every tank.
Old Oct 30, 2010 | 10:32 AM
Awesome. Keep it coming........
Old Oct 30, 2010 | 11:02 PM
Teich's Avatar
use Powerup in every fill 8ml/10l tested stanadyne reg. and perf. PS both red and white found Powerup the best starts better a little extra get up and go. Used in the Dodge,VW,Kubota, and Case tractor. Laurie
Old Oct 31, 2010 | 09:00 PM
PoorMansCat's Avatar
I use some Cat conditioner every great once awhile.. Maybe once every 10-15 tanks.. If that, plus good maintenance and being cautious about where I buy fuel won't keep it alive.. then it can just die!!!..
Old Nov 1, 2010 | 04:25 AM
HMX-1's Avatar
FPPF and Power Service every three tanks in fair weather, and then every tank in poor weather. If it gets really cold then I double up (2 quarts every tanks).
Kris
