06 rollover valve/vent hose recall
i have an 06 but dont have any recalls listed on the dodge website when i type in my vin. was this recall fixed at the factory after a certain date? and if so what date? also what is the recall about?
I believe the recall is for adding the fuel lines to the w existing vents on top of the fuel tank. I don't know about any cutoff dates. I took care of it myself when I did the Fuel Tank Vent mod.
I think what happens is dirt and grime build up around the valves and because they're recessed a little into the tank the dirt & grime could get into the valves and ultimately into the tank.
This is the dtr link to the rollover vent mod with pics.
https://www.dieseltruckresource.com/...ight=tank+vent
The other mod is the vent return relocation.Its not a recall,its a mod that you can do so as to fill your tank faster and with more fuel.About 4-5 gals more.You can find this at innertruck.com
This http://www.dodge.com/webselfservice/...m%28%27R%27%29
is the only one I know of. Is this the one you have already tried?
The one above or this one... http://dodgeram.info/tsb/2006-index.htm I am out of sites after these 2.
