06 oil pan gasket replacement cost?
Hey all -
Was up on a family camping trip this weekend, and I noticed that my oil pan is leaking at the back. I got up in there and tightened the bolts, but it didn't go a lot of good. When we got back into town, I took it over to the carwash and sprayed it off really good so I could see where it's leaking, and it's pretty obvious its the oil pan - I'm just glad it's not the rear main seal, or coming from the blowby tube....
Anyways, this looks like a bigger job than I can do since the engine needs to be lifted up.
Has anyone had this done recently? What was the cost? I have found older posts here from 2011, and they show anywhere from $600-$1200.
Good to know. I don't think this is the rear main - the mechanic I called had me check inside of the inspection plate to see if it was dry - it was. I got 3 quotes: $820, 998 & 1025. I talked with the $820 shop, and feel pretty good about them, so I scheduled the appointment.
Not sure about the '06s but earlier CR engines were known for leaking cam seals.....it's just a square shouldered o-ring....couple of bucks at Cummins but labor intensive to replace (trans has to be pulled). Have the shop check for that as well while it's apart.
Banzai Bob
Jul 17, 2007 11:08 PM
Common
Aug 24, 2006 06:31 PM
