'06 Hard Start
Old Feb 6, 2007 | 09:54 AM
mj007's Avatar
'06 Hard Start
My buddy has an '06 that is hard starting sometimes after warm-up. I know there is a TSB on the 06 for that BUT I can't find it. Anybody got that or have they had a reflash?
Old Feb 6, 2007 | 10:00 AM
bumpytruck's Avatar
I thought Genos garage has a list of all the TSB.
Old Feb 6, 2007 | 10:03 AM
Thundercloud's Avatar
I just took mine in to the dealer for that fix as well as some other little issues. I can not remember what the new TSB number it was but it was the most current one. The TSB website is quite a bit behind and needs to be updated. It your buddy takes it to the dealer just have him explain to the diesel tech that he has a hard start after heat soak nad he should be able to figure it out. I will go look at my paperwork and give you the TSB.
Old Feb 6, 2007 | 10:09 AM
mj007's Avatar
Thanks you guys! Yeah I was on Genos' list but as was said it's a bit behind. I'd really appreciate the number if you can find it, Thundercloud.
Old Feb 6, 2007 | 10:17 AM
My paperwork had TSB 18-19-06-02. Is your buddy able to retrieve any codes from cycling his key 3 times (off->run, off->run, off->run leave in run position and read codes, if no codes is just reads _ _ _ _ _ then -done-.
Old Feb 6, 2007 | 10:28 AM
mj007's Avatar
Thanks, man! Yeah, he's got a date with the dealer so maybe if he has this info they won't be able to give him a snow job so easy.
jacob_armour
Feb 18, 2009 01:44 PM
jckdann7
Aug 31, 2008 12:13 PM
jriggs_18
Jan 11, 2007 04:43 PM
Erik Dlux
24
Dec 8, 2004 07:26 AM
