05 vs 06 Automatic transmision????
Old Jun 23, 2006 | 06:06 PM
WEATHERBY460's Avatar
05....1,2,d,tow haul mode
06....1,2,d,tow haul mode, lockout od
Do I only have a 4 speed and the 06 is a 5 speed, sure seems that way, please explain???
Old Jun 23, 2006 | 06:34 PM
1fstdsl's Avatar
They are both 4 speeds, the difference is in 06 you are able to lock out OD.
Old Jun 24, 2006 | 06:56 PM
abc4yew's Avatar
The 06 can lock up in 2nd gear but easily does it in third gear but unlocks to go to overdrive unless you have a commander to hold it locked. It is the first of the stock 48re's to be able to hold for an exhaust brake. It's the best of the rest for sure. Put on a decent Torque converter and it will hold up to a lot. ks
Old Jun 25, 2006 | 10:32 PM
boostjunkie1's Avatar
Didnt Dodge Beef Up the 06 Trannies? I read somewhere that they were making improvements to the 06 and up trannies with stiffer internals, and better materials???????
Thanks
Old Jun 25, 2006 | 11:58 PM
lt11le's Avatar
yes they beefed up the tranny for 06.
If you look at a sales brochure, it has all the improvements that they did to it.
Old Jun 26, 2006 | 11:43 AM
no_6_oh_no's Avatar
Take a look at an 03 brochure for the 48RE. Its the same.Aside from some changes to the TV system in 05 the trans is pretty much the same from 03 up.
Old Jun 26, 2006 | 03:11 PM
xyzer's Avatar
I think they are basically the same between the 05 and the 06 The one difference I noticed this weekend hauling 5 tons of hay is in the tow/haul mode it changes the shift points bigtime and locks in gear to help on the downhill side. The od lockout works the same as my 99 and 03....this is my first 48RE and they added the tow haul feature....seems to work ok.
Old Jun 26, 2006 | 06:36 PM
My 03 SO with the 47re was the worst combination of motor and trans that has ever been. The trans was terrible. It never left me stranded, but the darn thing would shift early, and the motor just didnt have the umph!! It was like it would hit a dead spot in the power band at around 62mph pulling anything over 5,000 pounds. She would just fall on her face. The new 48re is great in comparison. Shifts are firmer and better timed. The tow/haul and the OD Lockout is great. I'm really happy with the new truck!!
Austin'sDodge
Sep 12, 2005 10:38 AM
VADSLRAM
Sep 4, 2005 05:46 PM
Buzzman
Jul 5, 2005 05:35 PM
king d
Dec 1, 2004 07:06 PM
bkrukow
Sep 1, 2003 09:25 PM
