05 Ram Diesel cylinder 1 isnt fireing....
Old Dec 30, 2012 | 10:03 PM
Cadimanjd's Avatar
Oh man! Sorry guys I went back to work after spending 2 days working on it. Well it had no codes I pulled the #1 injector and pulled it all apart cleaned it. Pulled the fuel pressure sensor cleaned it and nothing no change. So the next day I pulled the #1 and #3 injectors cleaned them both again and switched them and it still idled rough drove down my street 5-8 houses and it started to run normal. So the next day same old rough idle. So some days it runs great after a short drive and others it runs rough till warm. I am so lost. So after CES is all packed up and gone Im taking it to the shop and let them have it for a few days. I miss having my awesome dependable truck.
Thanks for all the help guys and if anyone has anymore ideas please feel free to share.
Old Dec 31, 2012 | 05:14 PM
SmokyDiesel's Avatar
By what you have done you have eliminated the mechanical side of the problem I think you need go look at your electronics connections on the engine harness ground to chassis connections etc good luck
Old Dec 31, 2012 | 05:26 PM
Cadimanjd's Avatar
Yeah Im thinkn it might be the wiring harness for the injector because I found oil in it and if that is it at least its a cheap fix and just a minor pain in the keester.
Old Mar 26, 2013 | 06:06 PM
Cadimanjd's Avatar
Finally have an answer...
Ok so after a long awaited answers and parts I have a burnt valve. After they replaced the injector wiring harness's and then giving me the truck back saying it was fine I got it home and same thing from a cold start rough idle so I took it back they had it 2 weeks and said they found out my fuel pressure reg was bad so they replaced it and guess what same problems. lol so after 2 more fuel regs same thing and they dug deeper and figured out I have a burnt valve. So I just wanted to come by and give everyone an update and say thank you for all the help and advice.
Silverfox99
May 2, 2007 05:55 PM
Flashpoint
Feb 9, 2006 05:27 AM
Txwelder
Mar 28, 2005 03:41 PM
Journier
Nov 22, 2004 02:56 PM
