05' Plastic intercooler... possible leak
Old Apr 10, 2006 | 08:42 AM
trik396's Avatar
After installing a 2micron fuel filter setup in the engine compartment, I started the truck to check for leaks. All was good, however I'm hearing what sounds like an air leak. I'm pretty sure I never heard this before and it seems to be coming from the drivers side front radiator area. I've also noticed that producing my normal 42lbs of boost is not happening as of late. I'm thinking I may have a small leak somewhere. I went over all the hoses and snugged them up.
Are there any particular ways I can check for a leak? I was thinking about a spray bottle with some soapy water, looking for bubbles. Any opinions?
__________________
Old Apr 10, 2006 | 01:06 PM
sled4fun's Avatar
Running engine test with a spray bottle with water and liquid soap mixture. Spray all around every fitting and tank seam. You should see bubbles were it is leaking.
There are also sound sensing tools to find vacuum / pressure leaks, but are a little pricey for a one time usage.
You could also isolate the inlet and outlet of the system, plug it up on one end and rig some type of fitting on the other end to pump it up to say 35psi and again look for leaks with a spray bottle. You may have to do it this way if there is too much air turbulance from the running engine test with the spray bottle.
Good luck!
Old Apr 10, 2006 | 01:14 PM
Jfaulkner's Avatar
Muted User
you can also spray a small shot of ether at the place you think it may be leaking, if it revs up a little you'll know. The no touch tire foam works good for finding leaks in tires, could do the same here also.
Old Apr 10, 2006 | 03:55 PM
fredbert's Avatar
Air is leaking out, not in, so that gasser trick won't work, even at idle. But you could isolate and test things at 100 PSIG instead of 35. Then DC would have to put in a proper intercooler!
Old Apr 10, 2006 | 03:59 PM
marc03's Avatar
mine makes the same noise from the same spot and I have the metal intercooler.
Old Apr 10, 2006 | 08:18 PM
sled4fun's Avatar
I like that approach. INSTANT UPGRADE!
QWKRTNU
Jan 31, 2006 09:23 PM
05mxdiesel
Jul 11, 2005 02:32 PM
451Mopar
29
Jun 8, 2005 10:13 PM
6stringdiesel
Jun 6, 2005 01:22 PM
KBF
Mar 9, 2005 02:24 PM
