05 cummins smoke coming from breather
Old Jul 19, 2013 | 05:23 PM
Yamaha012's Avatar
I have a 2005 dodge cummins 3500 with 92k miles and i notice a little bit of smoke coming from crankcase breather is this normal
Old Jul 19, 2013 | 05:26 PM
Yamaha012's Avatar
Anyone have this problem
Old Jul 19, 2013 | 05:53 PM
carl48's Avatar
you do not have your sig filled out. a little is normal. with sig filled out we can see if you have something on there like a K&N air filter that is dusting your engine
Old Jul 19, 2013 | 06:07 PM
Yamaha012's Avatar
Sorry im new lol its all stock exept for edge juice with attitude ran on level 1 for fuel mileage
Old Jul 20, 2013 | 08:14 AM
carl48's Avatar
I do not think you have any problems but you do need to dump the edge and get a smarty jr. the edge causes the egt's to get to high and other problems on the 04.5 up trucks. the smarty will lower egt by 250* below stock on your 05. just load the program, all default options and level 2 power sometimes called tow mode
Old Jul 20, 2013 | 02:18 PM
Yamaha012's Avatar
My only issue is everyone i talked to said that the smarty is bad for an auto transmission and the edge defuels between shifts
Old Jul 23, 2013 | 08:53 AM
poindexter1's Avatar
Nothing wrong with edge , I've had mine on for 8 years , 85,000 miles, no issues ever , may not be as well liked as a smarty but just as good if used with common sense , not bashing smarty at all , there great no dought ,same with any programer, doesn't matter who's you have abuse it and you will tear s€%t up, that being said , when was the last time you changed the filter? If never it might be time to or try cleaning it.
Old Jul 23, 2013 | 06:41 PM
Yamaha012's Avatar
I havent honestly because i just bought the truck 2 weeks ago wht is a good after market intake
Old Jul 24, 2013 | 12:26 PM
Reelay's Avatar
X2, use your gauges and warning indicators. Use common sense as you stated.
Straight6
Aug 22, 2008 11:20 PM
deiseldog78
Nov 18, 2007 01:52 PM
jr22
May 14, 2007 11:02 PM
zero2zero
Mar 31, 2007 11:58 AM
Superduty12v
Apr 21, 2005 08:29 AM
