05 CTD Replacement Crankshaft source?
Old Mar 28, 2007 | 03:08 PM
scottmn1's Avatar
I am needing to replace a crankshaft in a 2005 Dodge Ram 3500 with a CTD. The crankshaft end was bent in a collision with a tree. Is the crankshaft available only through the Dodge dealer, or is it available through cummins or other sources? If it is available from the Cummins dealer, does anybody know the part #?
Old Mar 28, 2007 | 09:52 PM
Smkndzl's Avatar
Give your local Cummins distributor a call with your serial number and they can get you a crank for cheaper than you can get one from Dodge.
Old Mar 28, 2007 | 09:54 PM
dodgezilla04's Avatar
do you have pics of the crash that would bend THAT crank? hopefully you werent hurt
Old Mar 28, 2007 | 10:20 PM
Riddler69's Avatar
Crank
Wow..crash bent the crank. Are you fixing the whole truck or just salvaging the motor?
Old Mar 29, 2007 | 08:42 PM
scottmn1's Avatar
It isn't my truck that this happened to. I am just locating and gathering the parts to do the repairs with. The truck rolled down a long hill with nobody in it(manual trans) and hit a large tree dead center. The truck is fixaable even though the damage is severe.
CODODGE2500MAN
Mar 2, 2010 09:01 PM
vwjunkie53
Aug 13, 2008 08:16 AM
charger 69
Apr 30, 2006 09:32 AM
