05 Bottom Air Cleaner Housing Stud Bushings
Old Mar 14, 2020 | 02:57 PM
ajpulley's Avatar
On my '05, there are two plastic studs on the bottom of the bottom air cleaner box, and each points down. They are supposed to fit into two holes, one in each plastic bracket sticking out the front side of the battery tray. The holes are large and the studs are small. I presume there is supposed to be a bushing fitting in there someway or another? In the Mopar parts manual, I see two different bushings; 04573211AB and 04268295. There is no picture to reference either. Does anyone know which one I need, and what their orientation is?
Asking because I had a battery fire and the mechanic didn't finish the job completely. So, I'm finishing the small things overlooked. The new air cleaner box is way too floppy where the battery tray supports it.
Old Mar 15, 2020 | 05:15 AM
tryNto's Avatar
You are correct on the bushings needed. You need 1 of each.
The 1st number comes up to a different vehicle.
2nd bushing
dieseljrs
May 19, 2012 09:40 PM
Bluedually4x4
Jan 4, 2009 12:31 PM
msiminoff
May 23, 2008 02:50 PM
O.T
Jan 17, 2008 01:42 PM
bowtiestrkrsmkr
Oct 14, 2006 06:53 PM
