05 2500 4x4 poor fuel mpg and random idle stumble
Old Dec 21, 2022 | 12:28 PM
ConstantSorrow's Avatar
I have a 05 2500 4wd auto that I’ve owned for about 4 months. Routinely getting 13mpg. Stock height. The engine is stock still has a muffler and a cat. Trans has about 20k on rebuild. No blow by. Recently had Yukon free spinning locking hubs installed which had absolutely no effect on fuel mileage. Intermittently the engine stumbles at idle. Is the poor fuel economy related to the engine stumble? Any suggestions?
Old Dec 23, 2022 | 12:35 AM
westcoaster's Avatar
First thought is plugged cat and or muffler.
My fuel economy went up when my stock muffler rusted out years ago. I looked in it and it is very restrictive. Add a bit of soot and it is even more restricted....
A suggestion is to go with any of the aftermarket see through muffler systems. Yup, the exhaust is noisier...
Second item would be the pressure relief valve on the common rail for the injectors. My truck would get 19MPG (empty) no matter how fast/slow I would drive. I noticed an improvement in economy after the replacement.
However, after replacing the relief valve, the injectors started bypassing too much fuel so those needed to be replaced. At 300,000km they were nearing the end of their "average" service life anyway.
The stumble could be the Fuel Control Actuator on the back of the CP3 pump.
Neither the pressure relief valve nor the FCA are terribly difficult to replace, nor require exotic tools or procedures. Clean any loose dirt first, 24MM deep socket for the pressure relief valve. and a Torx T25 for the FCA
Pressure relief replacement (I'm not connected to the video in any way)
FCA replacement
Old Dec 23, 2022 | 07:54 AM
Fordzilla's Avatar
But it's a good noise...13 MPG is about what I get with my 2009, I just live with it......Ben
Old Dec 23, 2022 | 12:15 PM
Thank you for the response and advice. I will replace the FCA and relief valve. I will also discard the cat and muffler. 19mpg sounds much better I hope I can get it. I will keep you posted.
Old Dec 23, 2022 | 05:31 PM
Try not to go cheap on the parts...
Your saving labour and shop parts markup, so use that to invest in quality parts.
Merry Christmas!
Old Dec 23, 2022 | 08:06 PM
Will do…
Have a Merry Christmas too.
Old Dec 29, 2022 | 02:09 PM
haily grace's Avatar
Originally Posted by ConstantSorrow
I have a 05 2500 4wd auto that I’ve owned for about 4 months. Routinely getting 13mpg. Stock height. The engine Kodi nox is stock still has a muffler and a cat. Trans has about 20k on rebuild. No blow by. Recently had Yukon free spinning locking hubs installed which had absolutely no effect on fuel mileage. Intermittently the engine stumbles at idle. Is the poor fuel economy related to the engine stumble? Any suggestions?
How did you work it out ?
Old Dec 29, 2022 | 11:57 PM
Something to try with the intermittent miss at idle...
My truck would intermittently "backfire" when cold at idle after having the injectors replaced.
The googler turned up other people (some on this forum) back in the day with the same issue.
The suggestion was to disconnect the intake heater grid.
Sure enough, that appears to have resolved my "backfire" (actually more like a small pop out the exhaust)
Perhaps that would resolve your intermittent miss at idle?
Old Dec 30, 2022 | 10:01 AM
FMB's Avatar
FMB
Intermittently the engine stumbles at idle. Any suggestions?
My '03 began stumbling, like a miss in a gasser. Ended up being a bad injector. I sent them to F1 for testing and rebuild. Fixed the issue. (I had them rebuild the whole set) Truck ran another 100k+ miles before I sold it at 295K miles.
Back to morning brew . . .
WaywardSon
Jan 31, 2023 07:15 PM
kmltrucking101
Jan 19, 2011 03:50 PM
one54ton
Competition / Pulls / OffRoad
Dec 29, 2006 12:33 PM
Chipmunk Diesel
Oct 13, 2004 06:28 PM
wildbillnc
22
Sep 12, 2004 01:06 PM
