04.5 low top end power and P0148
Looking for some ideas, I have ready through all the threads I can find and haven't narrowed my problem down yet.
A little repair history:
New injectors, ran great.
Then hard starts with P0088.
Replaced FCA, starts great and no more P0088.
Now a P0148 and no top end power. Still starts great and idles perfect, no smoke. The low end power is normal, but it has no power when I really get on it. It will rev slowly to redline but has very little acceleration.
I swapped in a rail pressure sensor from a good truck, and no change.
I replaced connector tubes because I had not done so with new injectors, no change.
Just wondering if there is something obvious that includes the P0148 and everything normal except for low top end power?
Thanks in advance.
Thanks in advance.
I checked my fuel pressure relief valve, it had fresh fuel sitting in the top of it. I replaced it but have no change in my symptoms. Very normal driving other than lack of power on the top end.
Can anyone tell me what normal boost pressures are?
been fighting the dreaded p0178 code off and on for over a year. my symptoms seem to appear more in cold weather also. i have posted here about this code before and have done what moparman has done but also to no avail. moparman- keep us posted please!
Well the truck is fixed and running super strong. It finally came down the the Cascade Overflow Valve. I think I should have changed it with the FCA. It is only 40 dollars and takes no time to replace.
captntim
Feb 19, 2012 12:37 PM
RAMRODD
0
May 23, 2006 10:08 PM
