04.5 Lift Pump P0628
Hello,
Haven't posted in a while. I've got an 04.5 with ~80 k on the clock. Last night the truck stumbled, ran for approximately 10 minuts more then died. Code P0628 "Fuel Pump "A" Control Circuit Low" so I'm assuming this has to do with the lift pump. No, I don't have a fuel pressure guage.
Is this really the lift pump or can it be the control circuit for the fuel pump?
Anyway, question is:
How many of you have had issues with the replacement in-tank pump?
Thanks in advance.
Thanks in advance.
Causes:
WIRING HARNESS
TIPM (Totally Integrated Power Module) Fuse Pannel
FUEL LIFT PUMP CONTROL CIRCUIT SHORTED TO EXTERNAL VOLTAGE
FUEL LIFT PUMP CONTROL CIRCUIT OPEN
FUEL LIFT PUMP GROUND CIRCUIT OPEN
FUEL LIFT PUMP GROUND CIRCUIT SHORTED TO EXTERNAL VOLTAGE
ECM
Check fuses/relays and the condition of the connection @ the LP
WIRING HARNESS
ECM
Causes:
WIRING HARNESS
ECM
WIRING HARNESS
ECM
Will do! Thanks....
driftingfly
Jan 31, 2010 07:21 PM
Harley1
Nov 25, 2009 06:40 AM
ctd4stan
Mar 19, 2009 08:35 PM
