03 Electrical Problems
Old Jan 23, 2012 | 01:49 PM
d22019's Avatar
I'm currently working on an '03 that has a bunch of mostly lighting problems. None of the exterior lights work, no signals, brake lights, high beams 4 ways nothing except the interior lights. The radio,wipers, door locks, power mirrors don't work. I have checked grounds replaced batteries, checked fuses with no luck. Do you guys have any ideas to point me in the right direction?
I just realized I posted in the wrong place. If somebody could move it I would appreciate it, thanks.
Old Jan 23, 2012 | 02:47 PM
BigIron70's Avatar
Cummins Guru
Try pulling the codes first and see what you have. Possible Power Distribution Center or Front Control Module.
Old Jan 24, 2012 | 01:06 PM
jhenson's Avatar
Yep...sounds more like a control module problem to me. Those things control several different electrical items and when they go bad (or get fried!!) many things end up not working.
Old Jan 24, 2012 | 08:11 PM
d22019's Avatar
Just bought an FCM from dodge and put it on, same problem. I pulled the codes in the cluster and this is what it gave me...
A3 44-Battery voltage open
A7 00-Check sum error
AA 36 or 30-PCM messages not received
AD 00-FCM messages not received
00 00
Ive checked everything. I have 12.8 volts to every fuse in the box, no fuses blown, good grounds, new batteries. I don't know what to do now, I'm stumped. The only thing different is the cluster lights come on after a few seconds when the ignition is on.
DJ Turbo.
Oct 13, 2011 09:11 PM
David Kee
Oct 11, 2003 08:33 AM
FastSS
Sep 8, 2003 01:47 AM
FastSS
Jan 8, 2003 05:53 PM
TurboAZ
Oct 11, 2002 12:34 AM
