Water pump
Old Oct 27, 2011 | 04:06 PM
blacksmoke's Avatar
Water pump
Replaced the water pump today what a PIA Worked 6 yes 6 hours trying to get bottom screw in. Is it just me or are others having the same problem
blacksmoke
Old Oct 27, 2011 | 05:37 PM
Roadmedic's Avatar
Takes about a half hour.
Remove the air filter box and you can get right in.
Old Oct 29, 2011 | 03:46 AM
papaduck's Avatar
When I replaced my pump I had a little trouble getting the second bolt to go in but it didn't take 6 hours, probably only about 15 minutes.
Old Oct 29, 2011 | 08:51 AM
92'1stGen's Avatar
Took about an hour for me, hardest part was figuring the correct way to maneuver the old water pump to get it out from the little bit of space between the front of the engine and the fan shield.
Old Oct 29, 2011 | 09:59 AM
madhat's Avatar
Administrator/Jarhead
Huh. Took mine to the dealer, it was covered under the 100K Cummins warranty. 100 bucks, and they flushed and re-filled my coolant...
Old Oct 31, 2011 | 11:53 AM
mattk50's Avatar
took me about an hour and a half but i replaced all hoses,belt,and
t-stat
ted_pulliam
Oct 15, 2009 08:24 AM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
