oil leak have no clue what it is
Old Nov 4, 2010 | 09:33 PM
mazztroy's Avatar
Exclamation oil leak have no clue what it is
i have a 2004 dodge 2500 4x4, i noticed it was leaking alot of oil it just started 3 days ago i washed the spot so i could trace where it was comming from. it is ozzing out from in between the steel block and aluminum cover that the fan is attached to i belive it is where the timing chain is i could see that there was a gasket there, it only leaks when the truck is running. is this a simple fix i can do my self or what might it be? or does it need to go to the shop
Old Nov 4, 2010 | 11:56 PM
rebal's Avatar
I would try and tighten the cover bolts and see if one is loose that could stop it
Old Nov 5, 2010 | 10:24 AM
mazztroy's Avatar
thankyou ill check that out
24cindy24
Mar 19, 2005 05:02 PM
midwestdually
Nov 18, 2002 11:30 AM
kmripley
Nov 12, 2002 07:33 PM
Rammin On
Oct 9, 2002 01:47 PM
