Where can I find a good used park brake pedal assy ?
Old Aug 23, 2012 | 07:08 AM
dewclaw's Avatar
My park brake assembly snapped something internally now the brake wont set .
I have tried the auto recycler internet inquiries but no one has answered them .
I have a 99 2500 4 WD.
Any help ( or a good used assembly ) would be great !
Thanks,
Dew
Old Aug 23, 2012 | 08:10 AM
patdaly's Avatar
Any 94-2001 Dodge Ram should be able to interchange. Hit your local pick a part.
Old Aug 23, 2012 | 08:56 AM
dewclaw's Avatar
Yep , ok , I will try the local places. All of the trucks around here generally get sent over to sacramento. That is a bit of a drive for me. I have just gotten lazy ordering / finding what I need on the internet and getting it mailed to me . DAnged technology . Thatnks for the reply and for sayin what years are interchangeable. ; )
Dew
Old Aug 23, 2012 | 09:48 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I had to replace mine...Just a side note...They could be a pain..Remove your side kick panel and pull your rug back...I think there was 3 bolts...And one is way up under the dash...Don't forget that last bolt..
Old Aug 23, 2012 | 10:23 AM
SIXSLUG's Avatar
There's a good, huge junkyard in Spokane WA that will pull and send you parts.
Good supply of Dodge stuff.
Old Aug 24, 2012 | 09:40 AM
Redlinear's Avatar
Stick with 99 and 00 models. The e-brake assembly is different every couple of years.
99 up on 2nd gen MAY work fine, BUT, 01 and 02 are definately different. (just don't know if the difference matters).
98 and earlier are way different. Coil spring controlled.
Old Aug 24, 2012 | 10:48 AM
dewclaw's Avatar
Thanks for the good info Redlinear
Dew
Old Aug 24, 2012 | 11:12 AM
Redlinear's Avatar
I'd like to correct something.
1998 and 1999 use the same e-brake assembly. It's a coil spring release style assembly.
(If you crawl under your dash and look at it, it should be able to see a "coil" looking spring).
98 and 99 only.
roughstock
Mar 6, 2012 08:32 PM
BearKiller
Jun 28, 2009 04:56 PM
ImpulseHydro
Dec 3, 2007 10:35 AM
9512vCTD
Dec 9, 2006 02:25 AM
