wheel grease seals?
wheel grease seals?
I need to know if on a 95 4x4 CTD if there any front wheel bearing seals that are replaceable or even avaliable. I am led to belive there only complete assembled bearing/seal units that are NOT serviceable. The only front axle seals there are are the inner axle seals, correct?
Thank You.
Thank You.
No seals available, you replace the hub/bearing/seal assembly. The only serviceable seals are int inner seals. The drivers side must be done from the differential center section, the passenger side is done from the central axle disconnect.
Forty-Two
Oct 22, 2008 11:55 PM
Pav1973
Aug 8, 2007 04:34 PM
