wheel bearing
Old Jan 11, 2008 | 06:22 PM
digman's Avatar
wheel bearing
so i was working on my truck today doing numerouse things to it and i left the cotter pin out of the hub nut and forgot to tighten the hub nut so i put my wheel back on and go down the road, about 200 yards down the road it stoped turning so i stopped instantly put it in park and looked out the window to the wheel was slanted i was like errr!!! so i shut it off and take it all apart right there in the middle of the road and i notice a bearing on the ground and i look at the bearing and its all torn up. my question is if the hub nut isnt tightened up would it make the bearing go out like that so fast, or is it somthing else?
Old Jan 12, 2008 | 08:19 AM
high bid's Avatar
I replaced my front driver bearing thinking it was bad and it ended up being the brakes. Not sure where you're located but if its the same part you can have the hub/bearing assy, just come get it or pay for shipping.
Old Jan 12, 2008 | 01:59 PM
digman's Avatar
i live in indiana i wonder what the shipping will be
Old Jan 12, 2008 | 02:15 PM
dennhop's Avatar
That would definitely cause the hub assy to rip apart. Those hub bearings are extremely weak, the worst idea Dodge ever went with, and since most of them when you do pull them off, are stuck to the axle spline, with that nut being loose, and allowing the hub to vibrate as the wheel turns, it would rip that bearing out quick.
Old Jan 12, 2008 | 02:58 PM
slim51015's Avatar
The axle nut holds the bearing together.
silverbullet02
Oct 5, 2009 12:16 PM
Wilbur01
Aug 3, 2009 11:16 PM
wadecool
Jan 12, 2007 11:39 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
