Warning!! Intercooler Line Chaffing...Check Yours!
Old Dec 8, 2003 | 12:33 AM
Dieselhead's Avatar
I have an 02 2500 and just noticed that the battery cable looming on the pass side was resting on silver intercooler line. Well after 25000 miles, the battery cable looming has almost worn a hole in the silver intercooler line!
Check yours before it's too late! It came from the factory like this so I know I'm not the only one.
Old Dec 8, 2003 | 10:02 AM
Olratlr's Avatar
Re:Warning!! Intercooler Line Chaffing...Check Yours!
Thanks DIESELHEAD! Will check it out. ;D
Old Dec 8, 2003 | 11:34 AM
Palmetto_kid's Avatar
replaced both my lower boots with Pier's boots. man they were a booger to get on too.
Old Dec 8, 2003 | 12:25 PM
Dieselhead's Avatar
[quote author=Palmetto_kid link=board=5;threadid=23432;start=0#msg220179 date=1070904850]
[/quote]
Actually, it's wasn't the rubber boot, it was the actual silver intercooler line that comes out of the bottom of the turbo. It actually wore little ridges like on the looming into that intercooler pipe and it was pretty deep too.
That looming is some tough stuff because it didn't even phase that looming.
Old Dec 9, 2003 | 01:12 PM
FMF MX's Avatar
Rick Harvey noticed that happening on mine when he was changing the turbo..He cut a 4" piece of 3/8ths" hose, then split it lenghtwise, and put it on the battery cable as a buffer. Zip tied it in place..Works real well..
Old Dec 9, 2003 | 10:12 PM
jigdog's Avatar
thanks for the heads up dieselhead ;D
Old Dec 10, 2003 | 11:30 AM
Dieselhead's Avatar
So who else besides me and FMF has this issue? I wonder if Dodge will replace that intercooler line because mine's pretty bad.
Old Dec 10, 2003 | 11:42 AM
[quote author=Dieselhead link=board=5;threadid=23432;start=0#msg219991 date=1070865229]
.....the battery cable looming on the pass side was resting on silver intercooler line.
[/quote]..
what diameter is this line? i have a line probly 1/2" dia. that was being rubber by a loom in the same location you describe. i moved it up and twist-tied it to somthing out of the way to keep it from rubbing.
i think this is the same line you are talking about
Old Dec 10, 2003 | 03:14 PM
Dieselhead's Avatar
Yep... that's it. Did it wear into your silver intercooler line?
Old Dec 10, 2003 | 03:21 PM
i can tell it has been rubbing there, but it hasnt rubbed through.
jmlcolorado
Aug 22, 2013 10:08 AM
mullishacrew
Oct 30, 2008 09:29 PM
j
Nov 30, 2007 03:47 PM
Bersaglieri
Aug 1, 2007 05:24 PM
4x4dually
Jun 2, 2005 04:57 AM
