Uneven rear brake wear.
Old Oct 15, 2007 | 12:02 AM
dewclaw's Avatar
I pulled the drums off the rear of my '98 and found that the drivers side was in need of changing but the right side looked almost new ! ? Very little wear.
I bled the cylinder on the right side , bled a good amount of fluid from it, saw no air bubbles.
Im wondering what is going on here !
Maybe my self adjusters are not self adjusting ? ( guess i should have looked closer at that before putting it all back together)
Any clues out there ?
Thanks ,
Dew
Old Oct 15, 2007 | 09:20 AM
infidel's Avatar
If your self adjusters were working I'd be very surprised.
The Dodge self adjusters have a well proven record of not working.
Old Oct 15, 2007 | 10:39 AM
dewclaw's Avatar
Ok, I will be popping that drum off for a peek , thanks
Old Oct 15, 2007 | 10:57 AM
Geico266's Avatar
Better get used to adjusting them on your own, I like infidel's recommendation the best, 2-3 clicks every oil change. This is done by removing the rear most oval inspection / adjusting plug on the inside of the drum and taking a screw driver and turning the "star adjusting screw" 2-3 clicks.
Old Oct 15, 2007 | 06:56 PM
infidel's Avatar
Not quite my method Geico.
Way I do it is jack both rears off the ground and turn the starwheel upwards while spinning the tire. Stop when it just starts to rub then do the other side.
First time you use the brakes the shoes will equalize and the shoes will no longer rub.
When I adjust at each oil change I usually get about 3 clicks off the driver's side but over ten on the passenger's.
Old Oct 16, 2007 | 06:54 AM
dewclaw's Avatar
Thanks for the input , I will be puting a new set of shoes on then keep up on the adjustments.
Thanks once again , this is a great site
Dew
dieselfuelonly
May 1, 2011 02:37 PM
trt490
Aug 9, 2007 09:46 AM
qwest
Oct 7, 2006 12:13 PM
JimmieD
Oct 5, 2006 10:27 PM
gabbyfan
Jul 9, 2005 03:04 PM
