turn signal
Old Apr 24, 2004 | 09:31 PM
Jambbii's Avatar
turn signal
My left one is not working and the brake dosn,t work either, just the upper light. But it does light up when I turn on the lights. Its not the bulb or fuse. Any suggestions?
Old Apr 24, 2004 | 10:10 PM
Crimedog's Avatar
I think it is the bulb, because it has two different "brightness wires" (sorry about the technical lingo ) The brighter strand probably burnt and broke.
Old Apr 24, 2004 | 10:23 PM
torquefan's Avatar
If a bulb doesn't fix it, it could be the left brake/signal wire, anywhere from the turn signal switch to the lamp itself. My guess is corrosion under the rear bumper area, usually where trailer wiring is spliced in. Could also be a bad splice in the harness along the left frame rail if someone has added a fifth wheel connector in the box.
May also be a bad multifunction (turn signal) switch, but wiring is the most likely.
Turn on your left signal and check power at the socket first, then continue upstream until you find power. Don't pierce the wire's insulation or it will corrode there. Unplug connectors and check for power at the appropriate pin.
Old Apr 24, 2004 | 11:17 PM
jrs_dodge_diesel's Avatar
I bet it is the bulb. It usually has two filaments, the "brightness wires" that Crimegog is referring to. The dual filament bulb has one filament for dim, and one for bright. Parking and running lights use dim, turn signal and brake use the bright. I bet if you pulled the bulb you would see a burnt filament. Good luck.
Old Apr 25, 2004 | 11:56 AM
Jambbii's Avatar
Geeze guys I said it wasnt the bulb , the reason for this? I already replaced it Anyways it does have trailer wiring in there. I will have to trace the wires and check it out.
Old Apr 25, 2004 | 01:24 PM
Partsman's Avatar
If it lights but doesn't blink check the front bulb. Also check for a good ground, grounds can cause all sorts of problems.
Old Apr 27, 2004 | 12:01 PM
pmtg's Avatar
my truck came with the trailering package, i bought it used and the wires were all screwed up...i tried fixing it myself and crossed a couple of wires i shouldn't have. i ended up blowing one of the fuses underneath the hood, have you checked those or just the fuse box in the dash? my symptoms were: no running lights, no dash lights, no blinkers, but i did have brake lights. just my .02
CanuckCTD
Sep 10, 2004 06:37 PM
ccolko
Jul 12, 2004 11:33 AM
hoot
May 25, 2004 11:52 AM
Richard Cox
May 20, 2004 11:21 AM
