Transfer case gearing?
Old Mar 26, 2006 | 10:21 AM
kawi600's Avatar
Is it possible to alter the gear ratio inside a transfer case (rather than both ring and pinion sets) if you wanted better cruising RPM?
Old Mar 26, 2006 | 03:22 PM
Tate's Avatar
2wd an 4hi are a direct drive through the t-case. You can get aftermarket gear sets for deeper low ranges, but that won't help cruising rpm any.
Old Mar 26, 2006 | 04:27 PM
TRCM's Avatar
only way to do that, is either swap axle gears, or put a overdrive unit between the trans & tcase, or on the tcase output if you only want to use it in 2wd
wyododge
Aug 18, 2011 07:48 AM
csramsey640
Jul 6, 2006 04:44 PM
8mpg
May 22, 2006 01:35 PM
malibu
Feb 18, 2003 07:21 AM
