which tires?
which tires?
I'm shopping for new tires. i have a limited budget. I was wondering about the Hercules terra trac a/t. has anyone here had any experience with them? Any help sure would be appreciated. Thanks, Marv
I had the Hercules tires on my truck before going with HanKooks..
The Hercules are OK..But they are a cheap tire....and the wear is not the best..I think I got about 15K miles out of them..if that
the Tera Trac HT wear fast as do the radial rib , the AT are real good tire, and there trailer tires (st)seem to hold up real well. we have over 200 tires on the ground and have switched over to Hercules 4 years ago they seem to be doing a good job for us. most of the time there over loaded .running Toyo just got to expensive so we bought are own changer and balancer and buy wholesale now from Hercules
Well that's good to know. Dang it. I thought maybe I found an ok tire that I could live with. I can't spend 900 dollars on a set of tires and have them wear out in 15,000 miles. So on with the search
Like I said...they where not bad..but they did wear fairly quick...If you could get them for way less than $900..It's a ok tire if your budget, is a little tight..
That was the reason..I bought them...tight budget...
Look no further
http://www.multimiletires.com/tires/...ication=SUV-LT
best summer tire I have ever owned, never got a flat, quiet, great handling and lasted nearly 60,000 miles. My father still has a set on his chevy that we bought back in 1996 (his truck spends most of its life in a heated garage). I seem to always get flats and have odd tread wearing when I use the Chinese and other less expensive domestic tires.
http://www.michelinman.com/tire-sele...2/tire-details
May 29, 2009 10:24 PM
Bradleysram
19
May 12, 2009 08:36 AM
sakisaki400
23
Dec 31, 2006 10:17 PM
