Thuren track bar help
Old Oct 19, 2008 | 08:28 AM
1qckdodge's Avatar
Hey guys, it appears that the bolt that runs threw the ball end of the bar was put in the opposite direction, further more I thinkk the bar needs a rebuild on that end, problem is I cant get it out, the nut is off, and I had the wife turn the wheel to get the pressure off the bolt but no luck, do I need to remove the bolt from the axle side as well? its no big deal to re-center the axle but I wanna make sure I put it back in correctly and make sure it doesnt need to be rebuilt, If it does then I might be the 1st person to tear one up, Thanks for any help.
Old Oct 20, 2008 | 11:40 AM
Big Deezul's Avatar
you need a separator like this
Old Oct 20, 2008 | 01:41 PM
SIXSLUG's Avatar
Yeah I was gonna suggest a good pickle fork and BFH! Watch the fender on your backswing!
Kurt
Old Oct 20, 2008 | 09:10 PM
1qckdodge's Avatar
Thanks guys I appreciate it.
Old Oct 20, 2008 | 10:15 PM
kawi600's Avatar
If you have an older thuren trackbar, you might want to mention the problem to don thuren before you just buy the rebuild parts. Some of them there was too much space between the tubing and the sleeve and it moved around so he has a different repair kit for that.
CTD2001
Aug 22, 2009 10:03 PM
silkywoods
17
Dec 3, 2007 05:09 PM
Mike D
Feb 27, 2006 07:22 PM
getblown5.9
25
Dec 8, 2005 11:52 AM
