Temp gauge is not registering
Old Oct 25, 2005 | 09:41 AM
Dave88LX's Avatar
I don't know if it's because it's not working, if it's the sender that's not working, or if I'm simply not getting over 140*? I also have no heat. I searched around and I was reading a couple threads on here about putting cardboard in front of the radiatior etc. I should still register on the temp gauge though no? It used to work excellent, up to 190°, drop down to 140°, back up to 190° and just cycle like that...
Thanks,
Dave
Old Oct 25, 2005 | 10:18 AM
John Faughn's Avatar
Becouse of no heat I would say that you may have a stuck thermostat , get one from cummins and you may not see the cycling any more, if it was a sensor , guage problum , use a muti meter and check for resistance , it should not be open , the exact res. is in the manual , or maybe someone will post it.
Old Oct 25, 2005 | 10:22 AM
Dave88LX's Avatar
I thought that cycling was what it was supposed to do as the tstat opened and closed though, when it was warmer out?
Old Oct 25, 2005 | 10:34 AM
Baja's Avatar
I had the same problem, no heat in the cab or gauge. The thermostat was the culprit, as it was stuck open. I always put a new one on a pan of water with a thermometer to make sure it works properly, before I put it in the vehicle. I had a new one not open at all, and almost fried the engine. A easy test is to take the old stat out and put it in a pan of water.
I don't think the "cycling" is normal. I have never had any car or truck in my life "cycle" up and down. The stat should open only as much as needed, not in a "all or nothing" mode.
Old Oct 25, 2005 | 11:04 AM
ccmckee's Avatar
The cycling is definately normal, the rads on these things is so big it drops the temp big time which closes the tstat until the heat builds up again.The only time mine doesn't cycle is in the summer with the a/c on and towing heavy then the tstat stays open as there is enough heat to keep it oepn.
If you ahve no heat then i would suspect your tstat is stuck open, there is a rubber gasket/sleeve that will distort and actually get caught in the tstat and hold it open. Go to cummins and get a new tstat and rubber.
Old Oct 25, 2005 | 01:00 PM
From what I've read it seems that the after market [ none cummins ] T-stats. have more problums, shorter life and cycle . I am the 2nd owner on mine and have not replaced it yet . and it stays steady at 180 , winter, summer,towing.
Old Oct 25, 2005 | 03:12 PM
Baja's Avatar
That is exactly what happened to mine, the rubber distorted and held the tstat open. It now runs at 180, no matter what I do to the load, or no matter how hot it is outside. Never cycles up and down.
Old Oct 25, 2005 | 04:28 PM
Dave88LX's Avatar
Yeah I have an AutoZone tstat in there. Appreciate all the help. I will see if I can find a local Cummins place and pick up a new tstat and see if that solves the problem. I still think it's crazy the lift hook is AROUND the tstat neck thing!
PADuallyBoy
May 10, 2015 02:28 AM
77machomopar
Jul 21, 2008 07:17 AM
Blessed
Jan 9, 2004 05:02 PM
richard
Nov 28, 2002 09:54 AM
