tailgate and bed
Old Dec 5, 2017 | 02:13 PM
rootercycles's Avatar
tailgate and bed
All,
I am putting together a 1995 Dodge 2500 regular cab 4x4, but have used parts from many year 2nd gens.
I had a bed painted, and am getting ready to place the tailgate on, but the mounts are different! They are both painted, so I need to use them. I hope someone has an easy fix!
I'll try and download pics of both the mounts on the tailgate and the truck to give an idea of the mis-match
Attached Thumbnails tailgate and bed-img_0397.jpg   tailgate and bed-img_0398.jpg   tailgate and bed-img_0399.jpg   tailgate and bed-img_0400.jpg
Old Dec 5, 2017 | 05:30 PM
04ctd's Avatar
looks like the gate slides over the post on one end, and then the other end is "keyed" and only slides over the post on the other end in a certain angle, via the open space?
Old Dec 6, 2017 | 05:31 AM
NO, it will not fit
Old Dec 6, 2017 | 12:03 PM
patdaly's Avatar
One didn't happen to come from a 2002 1500 did it?
I can't say I ever saw a different true 2nd gen bed that was different, but don't forget, 2002 1500's were technically 3rd gens.
Old Dec 6, 2017 | 10:02 PM
gorms's Avatar
The posts and bushings on the bed side look correct, I have never seen anything like on the tailgate on any year second gen. I wonder if it was aftermarket....
Old Dec 7, 2017 | 04:28 AM
That wouldn't be the end of the world if it was. I could just replace with the correct mounts then. Anyone have a source for what I need?
I know this is a 2nd Gen tailgate because I took the "guts" out of a 1998 Dodge 1500 tailgate, and everything fit perfectly. I'm baffled as to why the mounts are so different.
Old Dec 17, 2017 | 11:10 AM
I believe the tailgate I have is from a 1999. Any way to make this work without too much modifications?
Old Dec 17, 2017 | 12:02 PM
I have seen the bolt on style bracket before.
It is a stock Dodge tailgate. It allows you to bolt it on as an anti theft device I am guessing.
I bet you could bolt on the other style hinge and mount that tailgate right up.
If you can not find the right hinge, let me know and I will dig one up.
Old Dec 17, 2017 | 01:53 PM
I have that exact tailgate style on my '95 3500, but I know it is not the original tailgate for that truck.
I had that same tailgate with the bolt on bracket on my '95 I bought new as well IIRC.
Old Dec 17, 2017 | 04:34 PM
SIXSLUG's Avatar
That looks like an aftermarket anti theft device as mentioned above.
I just run a hose clamp over mine to slow them down.....
Old Dec 17, 2017 | 06:23 PM
you didn't look at both sides. Won't fit over pin on drivers side
Old Dec 17, 2017 | 07:29 PM
Well maybe you need to change the driver side hinge then...
Old Dec 18, 2017 | 04:47 AM
great advice!
Old Dec 18, 2017 | 02:59 PM
SIXSLUG's Avatar
Huh, the drivers side cup on the tailgate looks a lot smaller than mine....
Old Dec 18, 2017 | 07:18 PM
yesir, that's what baffles me. It is a 2nd gen tailgate, but different than other gates I've seen in the junk yard, and on other trucks. I can weld on the cups I need from another donor truck, but I thought there might be another, and easier way
