suspension overhaul, re-spring for no load + bags?
Old Aug 15, 2008 | 06:39 PM
kawi600's Avatar
Anyone out there taken a ram and replaced the springs / leafs and shocks to allow for more travel and a softer ride so the shocks can actually get a chance to do their job?
I drive mine mostly with an empty load and its breaking things off the truck it hits so hard.
Im thinking a combo of lower rate springs / leafs and airbags would do the trick but im curious if anyone has already gone this route and has advice.
Old Aug 15, 2008 | 09:21 PM
oldblues's Avatar
hi
i have the stock springs with air bags and ranchero air adjustable shocks and i can tell when the shocks get low on air psi .
with no load i only put 18 lbs of air in the bags and 150 in the shocks , gives the ride i like ??
if you are still running the original shocks they are surely shot!!!!!!
new QUALITY shocks would help big time !
Old Aug 15, 2008 | 11:13 PM
kawi600's Avatar
I tried rancho RSX9000's with the stock suspension, and now bilstein 5100's with skyjacker D25's up front and im still having problems.
for example.. I was doing a fast take-off and I hit a pothole and wound up in the lane next to me. not sure if that was the suspension bouncing or axle wrap.
But I have had the truck stumble towards the outside of a bumpy corner. It doesnt soak up anything
The suspension is scary and unpredictable when you need to do something in a hurry =(
Old Aug 16, 2008 | 05:27 PM
Ronco95's Avatar
I have given a little thought to using half ton springs for better ride unloaded and add air bags for load control. I actually had a relatively low mileage Monroe shock come apart recently while hauling another truck on a trailer. Had 10K added to mine and it road well loaded.
I am interested in following this thread further.
Ronnie
Old Aug 17, 2008 | 12:02 AM
Russ Roth's Avatar
Ronnie
That's basically what I did with my '67 Sweptline PW. I pulled 3 leaves out of the original spring packs and put air bags on it. Works pretty well. I want to replace the springs with 1/2 ton ones also. I had a 1/2 ton and it wasn't much for springs and they would work perfect in this application.
Old Aug 25, 2008 | 10:31 PM
LostCause's Avatar
I have 1 ton springs on my 3/4 ton, and it has the overload springs taken out. the other only thing i have is the cheap rancho shocks, and it rides smoother than my 1/2 ton did. it sucks b/c when i try to haul something heavy i almost bottom out, i need airbags
Outrage
Aug 3, 2015 08:52 AM
krawler-N-tow
Feb 23, 2009 05:09 PM
shoffs30
Jul 6, 2008 08:57 PM
Mule Skinner
Apr 10, 2007 04:49 AM
Stevie G
Apr 27, 2003 09:21 PM
