Air bags Suspension ??
Installed airbags last weekend, towed 4-horse trailer w/ living quarters this weekend (15K??) and w/ bags at 60 lbs under acceleration truck acted like some sort of shudder/slow vibration from rear end, let air bags down to 35 lbs and shudder problem symptoms went away, am I doing something wrong, did I even need the bags in the first place? A bit frustrating to spend $$ and may not have needed to. Do I need to change set up? Timbrens are still on the truck but w/ air bags pumped up not even close to hitting stops on axle.
Or is this just part of learning where to set pressures?
how did you make out ??
park on level ground hooked up... with LOW pressure...look at the carrier bearing...
then Put the air up where you had it and see if it is binding the bearing on the BOTTOM...
I have installed Firestone Airbags on my 1st. Gen.
There seems to be a narrow window of driveshaft/ pinion angle on these trucks.
I got a noticeable vibration when it was lifted about 2" over the stock height.
The cure was to install shims under the spring pad.
Jim
Jim
whiteeye42
Jul 6, 2011 06:29 PM
Clmsnow
16
Nov 27, 2009 03:57 PM
markp
Mar 12, 2008 04:22 PM
