Stupid Question/Fuel Filter Change Virgin
Hi all,
I need to change my fuel filter. It's starting to hesitate. I run B99 on a regular basis and have never changed the filter since I've owned it. It's a 99'
If I open the drain valve is that just water(and a little fuel) seperated out or is that fuel and all? I have the Chilton manual and think I can do this but any tips would be great. Thanks.
you have a 99 running b99 and never changed the filter? I am surprised that it runs at all. Just find a socket to fit the top of the filter and spin it off, take out the old filter, clean housing out if it is filthy, drop in new filter, and reverse directions to install. Bleed air from system and check for leaks.
You gave incorrect instructions for a 99.
The correct instructions are here:
http://www.dodgeram.org/tech/dsl/fil...uel_filter.htm
Maybe hes only owned the truck for a few months? He never said he was the first owner.
Stupid Answer
Floyd
interesting instructions, but..
I've change my filter a few times, but I've never needed to remove the water sensor..
never lubed the new filter
never pre filled the canister. not sure how this would be done without making a mess. just use the lift pump to fill and bleed the air out.
oh I own a 99..and use B100 most of the time
you might want to get a couple of filters
if you don't already have on..a fuel pressure gauge.
-dkenny
-dkenny
