Stiff steering
Old Mar 26, 2019 | 06:23 PM
maxpower's Avatar
Stiff steering
I have an 01 3500 2wd. I replaced the steering box and pump and it is much stiffer than the old one. I thought maybe it needed to break in but it's still really stiff, at all rpm's and speeds.
Old Mar 26, 2019 | 11:17 PM
SIXSLUG's Avatar
Sounds like you have some air in there.....the hydro boost doesn't like that.
Old Mar 27, 2019 | 12:09 AM
KATOOM's Avatar
What did you use for fluid? PS or ATF? And to get the air out of the system you jack up the truck axle so tires are off the ground. Start the engine, turn the wheel lock to lock about 5 - 10 times without touching the brakes. Turn off the engine and check fluid. If its low then add. If its aerated then let the truck sit for about an hour with the cap loose. Then tighten the cap and start the engine and repeat. After the second time the air should be out.
Old Mar 27, 2019 | 08:09 AM
maxpower's Avatar
Used ps fluid. Bled all air before starting. Truck has about 150 miles on it since the change, still stiff as a bear. Wondering if the reman shop over adjusted it during rebuild or if there could be an issue with the reman pump.
Old Mar 27, 2019 | 08:34 AM
Fordzilla's Avatar
Originally Posted by maxpower
Wondering if the reman shop over adjusted it during rebuild...
That would be my guess......Ben
Old Mar 27, 2019 | 09:33 AM
Personally, I would not touch the preload on the gear box. It's either aur bound, or the ps pump isn't developing enough pressure.
AJMartin0321
Nov 26, 2008 07:23 PM
gizzi
May 17, 2007 04:46 PM
BigBlue
Feb 9, 2007 04:03 PM
NorCal Ram
Jul 12, 2006 01:19 PM
John H
Nov 3, 2003 07:22 AM
