Starter problems
Well, My 11 year old starter is finally starting (no pun) to give me trouble. I think it must have something like a "dead spot". Usually when it's warm I have no trouble, but in the morning or after work a lot of times when I turn the key I hear 1 click from the relay or solenoid and nothing happens. May have to turn the key off and on 5 or 6 times, then it cranks up just fine with plenty of starting power. Do I need to replace the whole starter, or I notice this starter has replaceable brushes. Will maybe new brushes and a new solenoid fix me up ? How long do I have before I am stranded ???
Go here. Get the contact and plunger kit to rework starter. As long as all else is good in starter this should help you out.
http://www.fostertruck.com/dodge/default.htm
Mine was doing the same thing, found a good site that was very helpful
fixinrams.com . Pete has been a great help and has some good tips too. He sells stuff on ebay also, the starter kit came with a CD that will walk you thru the job too.
I have repaired several of these solinoids with just new contacts. The plunger should be cleaned carefully, at the end of the little spring is a round steel ball don't drop it . The brass circle on the plunger can be cleaned carefully if it isn't burnt too bad. Put a little grease on the spring when reassembling. I buy my contacts at a local rebuild shop. Hardest part of job is the top mounting bolt, I use a stubby wrench to take out first before loosening the bottom ones. good luck.
I just replaced my starter solenoid contacts yesterday. Took just alittle over 1 hour. The 12 point 10mm rachet wrench with no off set worked great, even on the top bolt. The kit was from fosters truck and it also included a new contact plunger.
The only downside is that I wished I had replaced them sooner, very basic wrenching.
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
