Sport conversion and fog light problem
I recently upgraded to the sport headlights, wired them correctly, and now have the fog light issue.
When I turn the lights on with out the fog lights, everything works as it should. When I turn the lights and fog lights on it works on low beam just fine. When I switch to high beam, the fog lights go out as they should normally. When I switch back to low beam, the fog lights come back on, but the high beam bulb stays on, and the low beam bulb goes back to low.
Any one else had this issue? If so, I would like to know what they did to fix it.
I finally figured out the solution to the problem. Someone at TDR had the same issue. All I did was jumper the fog light relay in the fuse block. That took care of any issues with the lights.
DIESELWRKS
32
12-25-2014 11:10 PM
fade94
09-15-2009 12:53 AM
Doj Dewd
ABDTR #5
19
05-19-2009 10:05 AM
Turbinator
08-30-2007 09:37 PM
