Sport light conversion :)
Old Dec 31, 2006 | 08:20 PM
d0dg301's Avatar
Well I finally received everything from the fedex guy and did the swap this weekend. WOW, what a difference they make. I bought the lights from Importvision Motorsports and the harness from Suvlights.com. Was a simple project and I didn't even have to drop the bumper down.
The only problem that I had was that when I turned on the light switch the relay's started buzzing and the lights blinked off and on real dim. Figured out it was my DRL module so I unpluged it ran a jumper wire so that my high beam indicator on the dash still worked and now so far everything works great. Well worth the money spent. The clear lens' look good too.
Old Dec 31, 2006 | 10:03 PM
roysleight's Avatar
Yesser, I sure like mine. Well worth the money. Happy New Year!
Old Jan 1, 2007 | 02:48 AM
1-5-3-6-2-4's Avatar
subscribe
bookmark links
sport fixtures and relay harnesses is my next upgrade in the new year
Old Jan 1, 2007 | 03:08 AM
LtsGo4ARide's Avatar
d0dge301
Could you please tell me what is the DRL module? I have installed the Sport lights already but I'm waiting for the wiring harness from Suvlights.com. I though all I would have to do is plug the truck wiring loom into the new harness and then plug the four new light bulb sockets into the sport light. This jumper that you set up does the harness come with instructions to wire it? Thanks, Carol
Old Jan 1, 2007 | 11:35 AM
JTMcCracken's Avatar
Is this a straight bolt on, and what is the total cost of parts?
Thanks,
JTMcC
Old Jan 1, 2007 | 12:52 PM
d0dg301's Avatar
Originally Posted by LtsGo4ARide
d0dge301
The DRL module is only on the Canadian trucks which I have and it is for the day time running lights. If your truck is not from Canada you'll have nothing to mess with. The jumper is only for the DRL module. Just plug your harness in and hook up the power to the battery and you'll be good to go.
Old Jan 1, 2007 | 12:57 PM
d0dg301's Avatar
Thanks,
JTMcC
It's a straight forward bolt on upgrade. Three screws hold your headlight assembly, pull thoughs and pop out the old and in with the new.I am into it for $343.00. Not cheap but it is worth it, IMO.
Old Jan 1, 2007 | 06:27 PM
could you run over what you did with the DRL jumper? for guys in canada like me. Thanks
Old Jan 1, 2007 | 06:51 PM
Wolfeman's Avatar
Early model trucks ( 98 - 99) might need some metal cutting. I had to cut out about a 4" square inboard of the existing hole - this is behind the light so it desn't show.
Old Jan 1, 2007 | 07:29 PM
d0dg301's Avatar
I got this off of another forum. Basicly just jump the two red wires.
http://www.turbodieselregister.com/u...=23525&width=2
Old Jan 3, 2007 | 10:17 AM
d0dg301
Thanks for the information. I don't have a Canadian truck but I wish I had day time running lights. Take care and have a Great New Year, Carol
Old Jan 3, 2007 | 05:43 PM
Dshiftff's Avatar
we need some pics!
josterbauer
Feb 15, 2012 07:31 PM
Turbinator
Aug 30, 2007 09:37 PM
mamm7215
Jul 15, 2004 08:08 AM
brianflynhigh
14
Mar 19, 2004 01:48 PM
