Seat belts
Old Oct 14, 2010 | 07:45 AM
SKINTBACK46's Avatar
Seat belts
My 99 dodge SLT Laramie 2500. Both front pass and drivers side seat belts will not release. Have checked fuses and things like that to no avail, all fuses are good. Anybody else faced this issue before? I'm going on a trip thru a couple of different states very soon and don't need to get pulled over for no seat belts.
Old Oct 14, 2010 | 10:07 AM
infidel's Avatar
A bad central timer module can cause this problem, it will also drain your batteries if parked for long.
Old Oct 14, 2010 | 10:13 AM
central timer module?
Where would that be located, can I do this myself?
Old Oct 14, 2010 | 10:54 AM
infidel's Avatar
Sorry, I'm not sure where it is on a '99, maybe someone else will chime in.
Some are under the dash, others under the seat.
Replacement is easy, just unplug the old one and replace it.
The CTM is about $125.
A bad CTM will set a code, maybe on a '99.
'99 is a weird year for the electronics, you can't do a self check with the key off and on trick, have to use a scanner.
My suggestion rather than throw an unnecessary part at the problem would be to go to an auto parts store that scans for free. O'Reilys is one that I know of that does it.
hipsi
Nov 14, 2007 12:36 AM
taildragger
Dec 1, 2005 12:07 PM
jsteezy1290
Oct 18, 2005 08:51 PM
AggiePhil
Feb 8, 2005 03:31 PM
ramlovingvet
Mar 30, 2004 06:54 AM
