Right front brake locking up
It's locking up at low speeds such as coming to a stop sign. There is also a squeaking noise from the same area that goes away when the brakes are applied.
A month ago I replaced the rear shoes and drums. Also replaced the front rotors and pads at the same time. I lubed all the pins and adjusters very well. I have had 1 ton chevy wheel cylinders for a couple of years already.
Sounds to me like the right front is hanging up while driving maybe?
Sometimes the hose will have a puffy looking spot on the outside.
What happens is the plys separate inside the hose and a flap hangs down making a one way valve that doesn't let the fluid bleed back when you let off the brake.
Wheel bearings make noise more so than pulling. Prying the calipers out to replace pads got piston sticking. I recomend replacing both calipers at same time. My luck is two months later the other hangs up.
Vert
Dec 19, 2013 07:42 PM
seahawkdodge
May 12, 2009 11:30 PM
00Dog
Sep 19, 2006 05:21 AM
xp8103
Dec 25, 2005 09:45 AM
