Replaced starter, now electrical problems
Old Jun 30, 2019 | 08:56 AM
Matt Hennen's Avatar
I’ve got an 02 Ram with a 5.9 Cummins and 5 speed manual trans. I just rebuilt and reinstalled my starter. When I turned the key I had no power to the dash. All of the fuses under the hood checked good. Then I put some battery post shims on the negative terminals because the cable clamps were still loose after max tightening. Now, some of the time, when I turn the key, the dash lights up, but when I try to engage the starter, everything goes dark again.
Where red do I need to start looking for the problem?!?!
Old Jun 30, 2019 | 09:26 AM
Fordzilla's Avatar
You might get better response in the 2nd Generation forum, but in the meantime after you've load tested your batteries, I'd start with the problems you've identified already, insufficient grounds...And use a test light for checking any circuits......Ben
Old Jun 30, 2019 | 11:07 AM
I unplugged the light and everything began to work. Coincidence, or what?
Old Jun 30, 2019 | 12:59 PM
AlpineRAM's Avatar
Which light did you unplug? Where?
al5608
Dec 17, 2011 12:34 PM
JWHenson
Aug 9, 2010 04:31 PM
TucsonDiesel
14
Jun 25, 2009 02:32 PM
2500
Oct 15, 2006 06:27 PM
JackRAK
Apr 23, 2006 10:33 AM
