Rear Disc Conversion Kits
Old Jun 4, 2014 | 12:01 PM
Wesley Angel's Avatar
drum to disc conversion
either buy a rearend off ebay with the disc set up.( I found mine for $200) way better than $2000 and rearend remove and install is a breeze. but if your going to do it from a kit. strip down all the way to the dust shield and take it off also... everything the axle gets a seal and the rest is pretty straight forward as far as caliper mounts n stuff. dont need brake line or anything unless the 1 you got is dry rotted only problem I ran into was the ebrake on passenger side worked up fine on driver side it changed a little bit just need a little longer 1 5 inches at the most nothing you cant do you can do the whole job in a day. good luck
torq_crowe
Mar 11, 2009 01:22 AM
dieselcarpenter
Dec 31, 2007 04:51 AM
mhuppertz
Mar 10, 2007 08:28 PM
scottmn1
Nov 19, 2006 08:21 PM
broncobilly
Oct 11, 2006 09:59 PM
