Rear brakes release under hard braking
Old Feb 3, 2021 | 11:53 PM
AggieJustin's Avatar
Originally Posted by AlpineRAM
Watch your speedo- does it register from 1-2 mph up or does it "jump" up to a certain speed like 10 mph?
If the latter, do a proper axle oil change with a cleaning of the sensor in the diff.
On a 20 year old truck I would not try to just pull the sensor from the top, the bolt likes to snap off.
If the sensor has a beard of metal you get no reliable speed signal, and the RWALB would rather have you brake moderately than spinning off the road.
In some rare cases I had a similar phenomenon due to the proportioning valve that opened too much due to the rear axle unloading.
(You wrote that you don't have one, but I think this is curious, it should sit in the driver's side frame rail slightly forward of the axle. There should be a lever connecting to a pushrod that goes to the axle. Maybe someone just wired the lever up or something like that)
The speedo is perfectly smooth and always agrees with my GPS registered speed. It is time for a rear end oil change, so I'll check it out when I have the cover off anyway.
As for the load sensor/proportioning valve, it doesn't exist on my 2001. I checked my FSM and there is no reference to it, just the proportioning valve that is built into the combination valve. I've also been over all the brake lines and there is nothing between the front and rear as a valve.
I was playing with it a bit tonight. When it would "release", I would try to push harder on the brake but it was pretty solid. I could release and reapply, but it wouldn't give much. I tried a few hard hits and it would lock the front wheels briefly and then release them. I'm going to need to find a scanner to check for codes, or better yet see what the ABS computer is actually seeing. Don't want to just throw random parts at it, especially if is the electronics.
Old Feb 5, 2021 | 03:23 AM
AlpineRAM's Avatar
Do you have RWALB or 4WABS in your truck?
The latter has an ABS sensor wire on each front wheel.
Old Feb 6, 2021 | 09:06 AM
It’s 4WABS.
Old Feb 6, 2021 | 12:27 PM
AlpineRAM's Avatar
Well, that was my brainfart then- 4WABS does not have the load sensing valve.
On 4WABS I have found that even the slightest bit of air in the lines, or drums that aren't adjusted properly lead to the problems you describe.
I prefer to fill those vehicles with DOT4 SL.6 brake fluid, it has a much lower viscosity and better lubrication characteristics.
You may have to activate the ABS module with a scanner to get a proper brake bleed on this truck, air stuck in the ABS module can drive you mad.
Old Feb 6, 2021 | 12:39 PM
So that’s the difference! I always knew there was no valve, but this is their first time I’ve seen why it’s on some and not others. It’s never mentioned in my FSM, so I just assumed it wasn’t on a 2001.
Old Feb 7, 2021 | 05:17 AM
AlpineRAM's Avatar
IIRC the 4WABS was standard from 01 on, instead of the RWALB with 4WABS option.
Double "L"
Jan 24, 2026 08:48 AM
Shipskym
Dec 21, 2013 11:08 AM
timb
Jun 3, 2005 09:11 PM
Dieseldude4x4
15
Feb 18, 2005 06:07 PM
Flashman
Feb 10, 2005 06:36 PM
